aluminum radiator
aluminum radiator
Postby siris » Wed Mar 10, 2010 1:53 pm
I don't have 170 bucks for a new radiator, but I do have a local picknpull brimming with c4c's. Anyone have an idea of cars i should look at for a donor rad? need auto cooling lines, pref on bottom.
siris
Re: aluminum radiator
Postby RusTy Max » Wed Mar 10, 2010 5:23 pm
I just pulled a radiator with an upper driver side and lower passanger side inlet/outlet. Then just find a hose that will fit the new angle. Bingo. Piece of cake. I know mine is almost twice the size of the stock one.
RusTy Max
Engine Size: 2.4L
Postby LethalEthan » Wed Mar 10, 2010 6:14 pm
If you can find one with the inlet and outlets in the right spot you wont have a problem even if you cant just get some aftermarket stainless hoses like I have on mine. The rad I have is made for a 240sx and the inlet and outlet are opposite of what I needed, so I just found some nice long hoses on ebay and ran them across.
LethalEthan
Engine Size: 2.3L
Postby TurboMax » Wed Mar 10, 2010 10:20 pm
I believe a Mits. Montero radiator will drop right in and has a thicker core.
TurboMax
Engine Size: 2.6T
Postby siris » Fri Mar 12, 2010 10:07 am
I was just wondering if someone knows of a rad that will fit pretty well. Like the montero, but i'd like to stay away from copper cored radiators. What did you pull yours out of rusty?
siris
Postby RusTy Max » Fri Mar 12, 2010 9:59 pm
Mine was already in a mighty max at the junk yard... so I'm not sure what it came out of... but if I had to guess I'd say a bigger sedan. Such as a caddy or buick.
RusTy Max
Engine Size: 2.4L
Postby siris » Sat Mar 13, 2010 9:48 am
i guess i'll go scroungin, and report back with my findings.
siris
Return to Cooling System.
