Ramit wrote:Or you could just buy that nice, brand new factory replacement,direct bolt on deal that Mike has for sale.And it would probably cost less than half of what you will spend altogether on the Weber and have none of the headaches of rigging up linkage or rebuilding the used one,or finding other installation parts needed.Just my .02
pennyman1 wrote:........ Should also change over to an electric pump putting out 4-7 PSI at 50 or above GPH to feed it the right pressure and volume; the stock pump will overpressure the weber and cause it to flood. Putting a pressure reg on the stock pump will just blow the pump out because of excessive back pressure, I know from experience. Get the whole kit with the adaptors for the truck; the jetting will be close.
