electric fuel pump for weber?
Postby slow50 » Fri Jul 23, 2010 3:23 pm
i remember on the old mightyd50 site some one found an electric fuel pump that had the right psi for a weber so you didnt need a regulator. anyone know what one it is? also whats the recomended fuel pressure for a weber?
slow50
Re: electric fuel pump for weber?
Postby dmr8x2 » Fri Jul 23, 2010 5:57 pm
4 psi,, i used a Mr.Gasket pump last fall for mine
$55 give or take
pumps push better than draw so put it closer to the tank as you can
the best place might be to place it where the fuel filter is then
move the filter to the fire wall next to the carb
and an oil pressure switch before the pump is a good idea too
QUOTE
Re: '88 2.6 Fuel Pump Installation
Postby pennyman1 » Thu Jun 24, 2010 7:25 pm
The oil pressure safety switch is a 3 prong switch with a common, NO(nornally open) and a NC (normally closed ) lug. With no oil pressure, the pump does not run, unless there is power on the NC side of the switch. This lug (NC) gets hooked to the starter solenoid. The NO side of the switch is hooked to a +12 volt power source. the common lug goes through a fuse and to the + side of the pump. This protects the motor by shutting off fuel to the engine when there is no oil pressure, including rollovers or side rolls and oil pump failures. The part I use is from an 76-79 4 cyl vega, I will post a part number in a later post. You will need a metric adaptor, as this is a standard 1/8 npt part. This should be part of any retrofit to electric pump install to prevent fires and engine damage. Drawing also to come.
dmr8x2
Engine Size: 2.4
Postby pennyman1 » Sat Jul 24, 2010 5:11 pm
I was running a 4 psi mallory pump but wasn't getting enough flow at wot so I went to a holley 7 psi pump - works better with my weber. Webers like hi flow pumps even more than pressure so make sure it is an 80+ gph pump.
Postby camoit » Tue Jul 27, 2010 3:41 pm
Facet pumps.
CHRYSLER-Imports
(except Conquest & F.I.)
1984 Colt, Vista, Station, All w/FWD Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
Wagon (FWD) Except F.I.
1983 – 1986 Colt 1600, 2000cc Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1983 Colt W/1400cc Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1983 Challenger & Sapporo W/2600cc Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1983 Ram & Power Ram W/2000cc Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
50 Pickup
1983 Ram & Power Ram 50 Pickup W/2600cc Engine PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1980 – 1982 All 4 cyl. 1400, 1600cc PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1980 – 1985 All
MITSUBISHI
1984 – 1986 All All except F.I. PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1983 – 1984 Pickup G54B PRO 60SV PRO 42370 PRO 42SV/PRO 04SV PRO 735 ----
1983 – 1984 Pickup G63B PRO 60SV PRO 42370 PRO 42SV/PRO 04SV
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Users browsing this forum: No registered users and 9 guests
