I have a 1990 max with the 2.4 5spd. I was wondering if the intake can be swapped and replaced
with a older style to carb it. I'm wanting to do away with the computer and as many wires as possible . Thanks for any info anybody might have!
camoit wrote:If I was you and it was running good I would stick with the fuel injection. It's just a better way of delivering and controling the air fuel ratio. If you go back to a carb you might be asking for trouble. Just my thought.
What I'm doing on my truck the carb is the only way I can go. Gear drive cams screw with Fuel Injection. Too much noise, they think they are pingging and retard the timming.
