mightyram50.net • View topic - 3.0 rebuild
3.0 rebuild
Re: 3.0 rebuild
Postby lush90 » Sat Jan 01, 2011 4:29 pm
Happy to hear it, it's really a great engine.
lush90
Engine Size: 3.0
Re: 3.0 rebuild
Postby DavetheDude » Sat Jan 22, 2011 8:15 am
Drove my pu to work yesterday and it runs good. It has a knock or tap somewhere in the top end. I'm very familiar with lifter noise and this doesn't seem to be what I'm hearing. It also does not sound like a bearing noise either. Does this engine, 3.0, have inserts for valve guides? Could I have a valve guide that is slipping? Any ideas? I've had several of my friends listen and we are all puzzled. Doesn't sound like a wrist pin either because it seems to come and go.
DavetheDude
Previous
Return to Head & Block
