mightyram50.net • View topic - plymouth laser dohc engine help!!
Postby leonwold » Sat Jun 05, 2010 12:44 pm
hi guys, so a friend of mine is looking to buy a 92 plymouth laser for $500, that has a fully rebuild and bored oversize engine and transmission with about 5000 miles since the rebuild. the issue is it has a broken balance shaft (2.0L dohc turbo engine). does anyone know how much work it would be to fix and if it would be worth it? thanks.
leonwold
Re: plymouth laser dohc engine help!!
Postby leonwold » Sat Jun 05, 2010 1:40 pm
its the mitsu 4G63T engine by the way
leonwold
Postby camoit » Sat Jun 05, 2010 3:33 pm
if u pick it up. put in the counter shaft DELETE kit. there known to lock up after rebuilding.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to Head & Block
