Jet valve delete
Jet valve delete
Postby defwin » Thu Oct 07, 2010 8:13 pm
Is it possible to make my onw or do I have to buy the kit?
WE have a fastener store hrer that carries every bolt and thread.
So what is needed?
Thanks
defwin
Engine Size: 2600
Re: Jet valve delete
Postby laidoutmits » Fri Oct 08, 2010 10:30 am
you can pull your bad ones out then remove the valve and spring, witch leaves you with the top and bottom and side holes. Just weld those 4 holes then grind smooth the side holes and reinstall the oring on the body and reinsert them.
laidoutmits
Return to Head & Block
Users browsing this forum: No registered users and 19 guests
