Hello everyone. I'm new to this forum. I'm looking for help with the ongoing lifter noise with the Mitsu engines. Can anyone tell me if I can swap out the cam followers with the hydraulic valves that my truck has for a cam follower from a earlier engine with the mechanical or "adjustable" tip. I have tried everything short of replacing the hydraulic valves. I have removed and cleaned per the Mitsu bulletin, used oil additives, and the rev up and idle fix. All do work with limited success, but do not last. I have checked and confirmed oil level also. The weather is getting colder in my area and this seams to affect the amount of lifter noise that the engine makes. If I have to pull the follower rails agian I want to make sure I solve the problem once and for all, and if I have to spend money on new hydraulic valves that "may" solve my problem I would rather replace with adjustable followers so I can control the amount of valve lash the followers have. I've heard alot of good things about this forum. Thanks for letting me on.
Carl
