87 2.0L
87 2.0L
Postby mighty max mafia » Mon Mar 28, 2011 9:01 am
Hey fellas i got a Q bout a truck i just bought its a 87mm 2wd automatic it over heats almost as soon as you crank it and its got water in the oil idk if the head is cracked or if its the HG. any help would be great its carbed to
mighty max mafia
Engine Size: 2.4L
Re: 87 2.0L
Postby LSR Mike » Mon Mar 28, 2011 9:04 am
could be a cracked block also, get out the wrenches....
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Re: 87 2.0L
Postby DroppedMitsu » Mon Mar 28, 2011 9:06 am
Its either going to be a headgasket or the head that needs replaced. Either way your going to have to pull the head so might as well pull it and find out which one it is. Remember when pulling he head you have to loosen the head bolts.in a certain order as to not warp the head.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: 87 2.0L
Postby mighty max mafia » Mon Mar 28, 2011 11:06 am
I din know that do you know the order?
mighty max mafia
Engine Size: 2.4L
Re: 87 2.0L
Postby DroppedMitsu » Mon Mar 28, 2011 12:10 pm
-Josh-
DroppedMitsu
Engine Size: 4g63
Re: 87 2.0L
Postby mighty max mafia » Tue Mar 29, 2011 6:06 am
Thanks!
mighty max mafia
Engine Size: 2.4L
Return to Head & Block
Users browsing this forum: No registered users and 18 guests
