2 Questions, 1 Engine, 1 Tranny
Postby jldavis1969 » Thu Oct 22, 2009 5:47 pm
Background: 1979 Dodge D-50 2WD approx 95,000 miles (could be more as former owner changed out the instrument cluster)
Engine Question: About a year and a half ago I took a trip to California from Salt Lake City, Utah. By the time I arrived in California I was having an overheating problem changed out the thermostat to no avail. I also thought I had a bad head gasket. Replaced head gasket and found a little spot that had failed. I got it back running and still had the overheating problem. I still have the original Exhaust Manifold on the engine. Could the Cat that is part of the manifold be plugged and causing the problem?
Tranny Question: Same truck has the 4 speed manuel trans. I got ahold of a 5 speed from a 1985 model and want to change it out for fuel economy reasons. Will the 5speed bolt up to the g52b motor?
Thanks in advance
Jeff in Utah
jldavis1969
What year vehicle do you own?: 1979
Re: 2 Questions, 1 Engine, 1 Tranny
Postby jldavis1969 » Thu Oct 22, 2009 6:11 pm
Have not measured it to be sure. The 85 had the 2.0 motor also
jldavis1969
Return to Questions That Don't Fit Anywhere
