stock gearing differences
Forum rules
Postby sassafrass » Tue Nov 30, 2010 12:28 pm
does anyone know the stock gearing differences between the diesel and gas 4x4 rigs. i assume there is some and if so is it in the diffs or in the tranny. in other words is the tranny the same (besides the hyr clutch control) and the gearing in the diffs or are the diffs the same and the gearing in the tranny is different.
thanks,
tom
sassafrass
Engine Size: 2.3
Re: stock gearing differences
Postby DroppedMitsu » Thu Dec 02, 2010 1:36 pm
These trucks came with a few dif gears for the differential. most came with 3.909, some with ~3.54 and some with ~4.xx
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby pennyman1 » Fri Dec 03, 2010 8:31 am
4.22 and 4.625 - Most are in the 2nd gen 9" rears of monteros, although some 3.0 V6 trucks had 4.22s in them. The 1 ton trucks also had 4.22s, but i'm not sure if they are 8 or 9" rear gears. Some vans also had 4.22s in an 8" gear.
pennyman1
Postby sassafrass » Sun Dec 05, 2010 10:11 am
ok, so you guys are saying the tranny is the same and the difference is in the diffs. the tranny in my gas truck is in much better shape, and i have to pull the engine/tranny to get to the rear seal on the diesel.
thanks,
tom
sassafrass
Engine Size: 2.3
Postby pennyman1 » Sun Dec 05, 2010 5:09 pm
Yes the trannies are the same. Just remember to change the speedo gear to match the rear gears.
pennyman1
Postby sassafrass » Sun Dec 05, 2010 5:27 pm
oh, thanks forgot about that. i was thinking i only had to do the hydraulic clutch....
maybe next week i will get to it...
tom
sassafrass
Engine Size: 2.3
Postby pennyman1 » Sun Dec 05, 2010 5:38 pm
I changed a tranny once in my 85 with one from an 84 without the speedo gear change - it was 15 mph off low, 55 was really 70. Had to go to the dealer to get the right gear, tranny was scrapped by the garage before i realized the speedo gear was wrong. I now do my own tranny changes, so the parts don't get tossed.
pennyman1
Return to General Talk
