eclipse engines
Forum rules
eclipse engines
Postby fixerupper10 » Mon Mar 29, 2010 5:03 am
hey anyone know if it really matters on the eclipse motors what year you get for a direct drop in? or will i have to make new engine mounts for a newer motor? Also what manual transmission can i get to fit it?
fixerupper10
Engine Size: 2.6
Re: eclipse engines
Postby TotallyBalistic » Mon Mar 29, 2010 5:38 am
not sure on the year but you wanna find the 4g63 with the 6 bolt flywheel, narrow block 5 speed trannys bolt up behind them
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Re: eclipse engines
Postby DroppedMitsu » Mon Mar 29, 2010 10:23 am
You preferably want the 6 bolt engines, 91-92(90 will work also, just has diffent electrical plugs on certain sensors).93-up will work also but they are the less desirable 7 bolt engines. Any of those years will work with stock truck mounts, but the cas and thermostat will be touching the firewall, so you might want to fab up some brackets to move it up an inch or two. The 5 speed manual(KM132) from a g63b(2.0L carbed engine) mighty max/Ram 50 will bolt right up to the engine.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: eclipse engines
Postby fixerupper10 » Mon Mar 29, 2010 10:28 am
wait so whats the manual transmission on the 2.4 carbed motors?
fixerupper10
Engine Size: 2.6
Re: eclipse engines
Postby DroppedMitsu » Mon Mar 29, 2010 9:33 pm
there is no 2.4 carbed. There is a 2.4 FI(4G64) with a wideblock tranny. There is a 2.6L carbed(G54B) that also has a wideblock tranny. The 4g63's are mostly all narrowblocks. so the only narrowblock tranny was the g63b tranny,KM132,
-Josh-
DroppedMitsu
Engine Size: 4g63
Re: eclipse engines
Postby fixerupper10 » Tue Mar 30, 2010 2:07 am
Whoops ya haha I meant the 2.6. Cool thanks for the help guys. Now just to see if pick-n-pull has the motor. I already know there not going to have the tranny.
fixerupper10
Engine Size: 2.6
Return to General Talk
