I need help. Broken Parts.
Forum rules
Postby g2k » Mon Apr 12, 2010 12:54 pm
Hey guys, I bought a 93 mighty with a 2.4, and thought it was a easy truck to fix. The original owner said it wasn't running good and it idled horribly. So a quick ecm swap and the truck kinda ran. There was some noise and a bad misfire. To cut to the chase, the cam gear is cracked and is flexing bad, and the power steering pump pulley is really messef up from somone trying to pry it off. So the big question, does anyone have these parts they want to sell, or know of a place I can get them cheap? My local salvage yards have no MM or D50's.
g2k
Re: I need help. Broken Parts.
Postby DroppedMitsu » Mon Apr 12, 2010 1:03 pm
try www.car-part.com . If there are local recyclers around you that have the part it will give you all their info.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby mxmikie » Mon Apr 12, 2010 3:37 pm
i proll have the cam gear got a picture ????
mxmikie
Engine Size: 2.4
Postby g2k » Thu Apr 22, 2010 6:06 pm
I don't have a picture, but I really need a cam gear for a 4g64 2.4L and a power steering pump pulley. I also need a a/c tensioner, I have the bracket I just need the bolt and the tensioner pulley. If anyone has any of this stuff laying around, I would gladly buy it off of you.
g2k
Return to General Talk
