What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby DarthWookie » Wed Nov 24, 2010 8:09 pm
Pull the stock wheels of the D50 today, taking them to my brother's house tomorrow and swapping him for a set of old school aluminum mags off his Luv. :dance: :dance:
where the hell are my PANTS!?!?!?!?
DarthWookie
Postby DroppedMitsu » Wed Nov 24, 2010 8:26 pm
Got the timing chain and cover and stuff back on my new macro cab. Now tomorrow I need to get the head and head gasket along with everything else back on it so I can get it running.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby 77amc » Wed Nov 24, 2010 9:19 pm
4doorciv wrote:Gotta bring this thread back to life..
Yesturday I got some used Oem dsm cams and cam gears for 80. The cams I got have too much overlap to run the oem fuelmaps and the set idle are too low. Cause a loopy idle and idle vac down to a sopping 9inhg. Doesn't wanna idle. And the cam gears I got are adjustible so I'm not sure how to read tdc on these yet.
Couldn't you just use adjustable gears or put the teeth one off or so??
What size cams are they?
E
77amc
Postby 4doorciv » Thu Nov 25, 2010 12:38 pm
They are webcam 546/547 grind at 272 duration with a little bit too much overlap. I don't understand the whole degree the cams stuff, so for now Ima put the oem cams in until I can get a means to raise the idle using the aftermarket cams.
Last night my battery died in my talon while I was at walmart. The ground wire I got is corroded really bad. Cut off about 4 inches of wire and still got corrosion in the wire. Bought a new terminal from walmart and took the optima battery out of the truck so I can drive around. Maybe tomorrow or Sunday I will replace the ground wire and add a few extra grounds for support on the talon.
Still waiting on parts for the truck in the meantime.
-Ryan-
4doorciv
Engine Size: 4g63
Postby camoit » Sat Dec 18, 2010 9:02 pm
I gave it some BIG NUTS..
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby beachrat92 » Fri Dec 24, 2010 9:30 pm
i watched the OD roll over to 180,000 miles today
- Dan
beachrat92
Postby ipods.rocks » Mon Dec 27, 2010 3:24 am
beachrat92 wrote:i watched the OD roll over to 180,000 miles today
i watched mine roll to 311,000 today
ipods.rocks
Postby 4doorciv » Mon Dec 27, 2010 12:51 pm
I watches mines just sit in the driveway. I thunk I gotta put air in the tires soon.
-Ryan-
4doorciv
Engine Size: 4g63
Postby sacredauto » Thu Dec 30, 2010 10:17 am
well, not today, but monday and tuesday i was going through 14 inches of snow and not getting stuck with super bald tires. little truck made me proud
sacredauto
Location: Northeast NC, Southeast VA, right on the border
Engine Size: 2.6L
Postby Spikey1566 » Mon Jan 03, 2011 5:55 am
i got mine stuck in a parking lot on a lil dip. i ended up ripping the bed on it. guess i gotta fix my air lines so i can raise it again when that happens
Spikey1566
PreviousNext
Return to General Talk
