What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby villacorta32 » Thu Sep 17, 2009 10:00 pm
where u get em at i got mine at autozone kerb
villacorta32
Postby qballd50 » Fri Sep 18, 2009 12:33 pm
Tue. My New Bumper Should Be In!!
qballd50
Engine Size: 2.6L
Postby TurboMax » Fri Sep 18, 2009 4:55 pm
MightyG54BTMax wrote:Took out the junk rad and put in the one from my Starion along with the electric fans and entire part of the harness. Took out all the wire nuts from previous owner and solder all connections. Made custom stereo brackets out of my Starion stereo brackets so the cd player doesnt skip with every bump. Started routing the Megasquirt wire harness.
You got pics of the starion radiator installed? Isn't the starion radiator wider then the truck radiator?
TurboMax
Engine Size: 2.6T
Postby Spicoli » Fri Sep 18, 2009 5:09 pm
Gabe, ebay for blocks, local store for bolts
--keRby
Ad Inexplorata
Spicoli
Postby shultz » Sat Sep 19, 2009 2:24 pm
Installed a new fuel tank to replace the original rusted one, changed fuel filter, cleaned the fuel lines. Started right up and roadtested and it ran good till it hit operating temp then it stills has a dead spot when trying to accel and acts like it wants to stall, if you push the accelerator a little more runs ok. Still a little more to do.
There only original once
shultz
Engine Size: 2.0L
Postby MightyG54BTMax » Sun Sep 20, 2009 5:26 pm
Yeah the rad is wider by quite a bit. I threw it in out of curiosity and saw that the mounting tabs ended up on flat spots on the rad support so I self tapped it in for now. Both the lower and upper hose from the truck still work (2.0L). I will most likely weld nuts on the rad support instead of staying with the self tappers.
MightyG54BTMax
Postby Spicoli » Sun Sep 20, 2009 6:25 pm
Took my waterpump off a million times trying to stop a leak and think I did. Then swapped an ECU into my V6 truck, no go back to square one...
--keRby
Ad Inexplorata
Spicoli
Postby shultz » Wed Sep 23, 2009 4:20 pm
Pulled the carburetor back off and send it back to the rebuilder, it's got a jet problem, double and tripled checked everything. Have to wait until it gets back, that should be at least a couple of weeks. :cry:
shultz
Engine Size: 2.0L
Postby LethalEthan » Wed Sep 23, 2009 4:26 pm
sucks to hear that shultz. only thing i did today was wash my truck
LethalEthan
Engine Size: 2.3L
Postby Johnboy72 » Mon Sep 28, 2009 2:33 pm
Well had to do something...so here's what I did today. JOY.
Before
After
Think it looks a little bit better. Might shoot myself later if I have issues with the needles during nighttime driving. Well have to have a running truck first. I'm sure the needles were better visible with the orange but who cares. I'll worry about that later.
Johnboy72
PreviousNext
Return to General Talk
