brakes
Forum rules
brakes
Postby fixerupper10 » Wed Apr 07, 2010 5:43 am
hey has anyone done a rear swap for brakes to go from drums to rotors? id rather pay the $30 in the future for new rotors than $60 for new drums
fixerupper10
Re: brakes
Postby MightyG54BTMax » Wed Apr 07, 2010 2:43 pm
I did, but its on a 2wd toyota axel.
MightyG54BTMax
Re: brakes
Postby pennyman1 » Wed Apr 07, 2010 5:40 pm
Get a rear axle from a montero or montero sport that has rear discs. I haven't had the time to try to swap the rear disc setup off a 2nd gen montero to a 1st gen d50 axle
Re: brakes
Postby fixerupper10 » Fri Apr 09, 2010 1:49 am
can i just pull the parts off the montero axel or do i have to pull the whole axel?
fixerupper10
Re: brakes
Postby pennyman1 » Sat Apr 10, 2010 6:11 pm
Its easier to pull the whole axle and cheaper in the fact that you don't have to replace bearings and seals on the rearend
Re: brakes
Postby payrion » Sat May 08, 2010 2:46 pm
pennyman1 wrote:Its easier to pull the whole axle and cheaper in the fact that you don't have to replace bearings and seals on the rearend
will this axle just bolt right in or will i need to weld new pads on it for the leave springs? also same width?
payrion
Re: brakes
Postby pennyman1 » Sat May 08, 2010 5:16 pm
If its from a leaf sring montero or sport, yes but it may be an inch wider. My 95 montero axle is a coil spring setup, so I haven't decided to mount it with bags ( I got all the arms and mounts to go with it) or cut the mounts off and hang on the leafs. The 95 also requires a driveshaft mod for the u joints. The 95 axle is a 9" rear like a ford 9" but much stronger, so I've read.
Return to General Talk
