need help-game plan
Forum rules
need help-game plan
Postby streetfighter » Sat May 15, 2010 7:20 am
thanks everybody for the warm welcome
...so this is my game plan i need some opinions
-long block p#meici5620c... its a 2.6l I4 reman mashall complete w/ new oil pump and balance shaft elimination Without pulse air and jet valve
-weber carb p#wk611
-pace setter headers p#60-1011
-nology wires
my goal is to re-vamp my truck so i can enjoy it for years to come so im not really going to hard on performance though i do want to put a mild cam and obviously with the after market carb i should get some what of a little kick outta it. im really thinking about an msd ignition but im not sure if that will be to harsh, be it that im going with nology wires. idk help me out
streetfighter
Re: game plan
Postby MightyG54BTMax » Sat May 15, 2010 2:00 pm
do you really want to pay that much money on spark plug wires that you probably wont notice a difference with?
MightyG54BTMax
Re: game plan
Postby pennyman1 » Sat May 15, 2010 6:57 pm
Some thoughts on your plans:
You can't run an MSD and Nology wires, they will conflict. Use NGK platinum plugs gapped .010 wider than stock with a high energy coil for best results. I am running my 1980 2.6 with all the same parts you are looking at, and getting 25 mpg at 75-80 mph.
Go with 2.25 exhaust all the way back with a high flow cat and a flowmaster muffler; a dual outlet one will give you the dual look and sound, with the performance to back it up
Lighten the flywheel on a 5 spd; stock is 30 lbs and slows spinup. 5 to 10 lbs will do wonders.
Get a taller air filter for the weber, the one that comes with it is too low for the air to flow in properly. the right height is twice the height of the one in the kit.
Re: game plan
Postby streetfighter » Sun May 16, 2010 6:52 am
thanks for all the advice but good you give me some direction as to where to get some of those things, my biggest issue is all the the only place i seem to get any info is on this forum ive researched for hours on end and have a hard time getting any where. ive been trying to find a light weight fly wheel and mild cam for a few weeks now lol and i wont give up till i find-em lol
streetfighter
Re: need help-game plan
Postby MightyG54BTMax » Sun May 16, 2010 2:30 pm
The only cams I've ever seen were regrinds from schneider cams. I have a 274 regrind in my 2.6. Findanza makes an aluminum flywheel for the 2.6 turbo out of a Starion/Conquest. It runs a 240mm clutch and pressure plate. I don't know stock size of the Mighty Max clutch, but I would assume 225mm the same as the smaller clutch in the Starquest. It's kind of pricey though. I paid close to $300 for mine. A machine shop should be able to lighten the stocker.
MightyG54BTMax
Postby streetfighter » Sun May 16, 2010 3:35 pm
thanks again for the help
streetfighter
Postby Ramit » Sun May 16, 2010 7:54 pm
If you go with a balance shaft elimination and a lightened flywheel, you had better get the whole rotating assembly balanced,otherwise, your engine is going to beat itself to death.
Ramit
Donator
Donator
Return to General Talk
