mightyram50.net • View topic - anyone know what this is??
Forum rules
Postby AOrolfo » Sun Jan 23, 2011 4:41 pm
2010-12-26_15-48-58_235 by aorolfo, on Flickr
it fell out of my car while drivin and now my clutch pedal is flimsy and has no pressure??
some people said it was my clutch cable, clutch arm, etc... just makin sure?
AOrolfo
Engine Size: 4g64
Re: anyone know what this is??
Postby DroppedMitsu » Sun Jan 23, 2011 4:58 pm
Yes its the throwout bearing release arm. Your clutch cable is attatched to it and disengages the clutch when you push the pedal. Get it welded back on and also have them weld it with A support so it doesn't break again.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby AOrolfo » Sun Jan 23, 2011 5:08 pm
do i have to pull the tranny out?
AOrolfo
Engine Size: 4g64
Postby DroppedMitsu » Sun Jan 23, 2011 5:22 pm
They might be able to weld it with it on the truck, just have to ask
-Josh-
DroppedMitsu
Engine Size: 4g63
Postby AOrolfo » Sun Jan 23, 2011 6:30 pm
you have any idea where its located??
AOrolfo
Engine Size: 4g64
Postby DroppedMitsu » Sun Jan 23, 2011 6:50 pm
Yea on the left side of the tranny towards the front
-Josh-
DroppedMitsu
Engine Size: 4g63
Postby AOrolfo » Tue Jan 25, 2011 2:56 pm
does any company make new ones of these?
AOrolfo
Engine Size: 4g64
Postby AOrolfo » Tue Jan 25, 2011 3:03 pm
so i dont need welding?
AOrolfo
Engine Size: 4g64
Postby 4doorciv » Thu Jan 27, 2011 11:54 pm
Did you try to ask the dealership if they still have this part available? Otherwise scrapyard searching for you if you dont want yours repaired.
-Ryan-
4doorciv
Engine Size: 4g63
Postby DroppedMitsu » Fri Jan 28, 2011 3:14 pm
He told me he was able to get one from the dealer
-Josh-
DroppedMitsu
Engine Size: 4g63
Return to General Talk
