wrngwae wrote:while you have the cam out and the springs off you can feel your "side to side" feel on the valve stems in the guides. if that makes any cents??????? move the valve side to side while the spring is off to tell your wear. also heat is the number 1 destroyer of these lil diesels. is your turbo water cooed as well???
i have had no over heating issues with the raider radiator but it is also alot larger.
wrngwae wrote:heat is the enemy on these motors. did your oil consumption stop???????
