No power and idoling at 2k rpms
Re: No power and idoling at 2k rpms
Postby tyler111991 » Sat Jan 29, 2011 8:57 pm
I used a shop vac and a longer hose to test it. At first it opened but after about 10 seconds it slowly closed. 75 sounds kinda pricey for such a seemingly simple part haha. I guess I will give them a call tomorrow. Thanks
tyler111991
Postby Ramit » Sun Jan 30, 2011 3:38 pm
Shop vac???!! Really? A little suction from your mouth is all it takes. Pull enough to open the butterfly, and use your tongue on the end of the hose to hold the pressure. Yes $75 is a bit steep, put even if you are able to find one at a junk yard,and it is still in working order, trust me , it wont last very long. The air bladders in them are dry rotted. So either buy a new one, or buy a carb that has mechanically operated secondaries.
Ramit
Donator
Donator
Postby tyler111991 » Sun Jan 30, 2011 8:05 pm
haha yep a shop vac, overkill I know but it worked :D Im leaning more toward upgrading the carb, the truck has 176K miles on it and should last many more, so I think it would be a good investment. Ive been doing some research on Weber carbs, Im trying to figure out if they are a direct replacement, and if all of my vacuum lines will hook up and stuff.
But I am liking the fuel milage of a 1 barrel carb, just not the lack of power :lol:
tyler111991
Postby pennyman1 » Mon Jan 31, 2011 6:55 pm
The only weber close to a bolt on is the 34 series emissions carbs - not a direct bolton, but not to hard to change, and definately will run better and still give good economy.
Postby tyler111991 » Tue Feb 01, 2011 9:25 pm
good deal. does Weber have a site they sell from or do they use ratailers? I found a Weber website... but it was bbq grills :lol:
tyler111991
Postby pennyman1 » Wed Feb 02, 2011 6:30 pm
lookup redline weber or joetlc on ebay for starters
Postby tyler111991 » Fri Feb 04, 2011 1:22 pm
ok thanks a lot
tyler111991
Postby CheapBastard » Fri Feb 04, 2011 2:32 pm
tyler111991 wrote:ok thanks a lot
Kind of lost here...? You were bitching about a $75 dollar part earlier, and now you are wanting to blow $300 on a new carb?
CheapBastard
banned
banned
Postby pennyman1 » Fri Feb 04, 2011 4:26 pm
Seems odd, but the truth is that the new carb will work better far longer than a old mikuni carb that probably needs rebuilt, or worse, worked on by some who shouldn't have touched it in the first place. Not to mention the chance to get away from all the emissions BS that those mikuni carbs were saddled with
Postby abeemanator » Sat Mar 05, 2011 11:32 pm
On my truck I have no ECM, and I was getting pretty bad mpgs, so what I did is I took the A/C vacuum control switch (The A/C is hooked directly to a toggle now) and I ran a vac line from the engine, to the A/c vac control, and hooked a vac line to the secondary. Then wired the vac control to a toggle switch. When I flip the toggle, the secondary works almost like a mechanical progressive secondary. Now I have full control over when I want the secondary to be on,it seems to work well, and Im pretty sure you could use it as a cheap temporary fix.
Beemanator
abeemanator
PreviousNext
Return to Hard Starting, Bad Fuel Mileage, stalling.
