1st gen plug to nowhwere related to headlights?
Postby sassafrass » Sun Nov 07, 2010 4:03 pm
i have been resurrecting a 1st gen diesel d50, and i have no headlights. i can't seem to locate a proper wiring diagram, and the best i can figure is this plug is somehow attached to the battery probably via some sort of fusible links/fuses.
it is a 6 prong socket located on the driver side right near the battery.
any help would be appreciated...
tom
sassafrass
Engine Size: 2.3
Re: 1st gen plug to nowhwere related to headlights?
Postby LSR Mike » Mon Nov 08, 2010 5:32 am
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Postby sassafrass » Mon Nov 08, 2010 3:58 pm
thanks mike. that is the same diagram i have, but it does not seem to indicate this junction. and this junction has continuity with the light sockets.
perhaps you or someone could tell me where "multipurpose fuse" 12, 14 and 15 are. the only fuses i have are the ones are 8 under under the dash. none of these are for the headlights.
tom
sassafrass
Engine Size: 2.3
Postby 4doorciv » Mon Nov 08, 2010 4:32 pm
You think the connector is for the fusable links? Sorry, I got a 2g truck. Mines are a little further back and in a weird box a little closer to the firewall.
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Mon Nov 08, 2010 6:36 pm
The headlights are fused through the fusebox, not the fusable links. squeeze the tabs together for the headlight fuses then replace the fuses into the holder. also check the fuses themselves, as when the holders get weak, they can start to vibrate ultrasonically and melt the solder out of the end of the fuse, but the fuse appears good.
Postby LSR Mike » Tue Nov 09, 2010 8:50 am
sassafrass wrote:thanks mike. that is the same diagram i have, but it does not seem to indicate this junction. and this junction has continuity with the light sockets.
tom
Hmmm.
My Fuse Cover (1992 mind you) diagrams it like this:
Top Row
1 Room, 2 Hazard, 3 Stop, 4 Horn, 5 Radio, 6 Wiper, 7 Turn, 8 Back, 9 Heater, 10 Blank
Bottom Row
11 Blank, 12 Tail, 13 Blank, 14 Head-L, 15 Head-U, 16 (Rear Fog), 17 Blank, 18 (Door Lock), 19 (DeFogger), 20 ABS (C/U)
So I think you may need to add some fuses...10 AMP for #12 15 AMP for 14 & 15.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Postby sassafrass » Tue Nov 09, 2010 2:59 pm
yes, the diagram i have and the one online here is for a 2nd gen. the headlights go through the main fuse at 14 and 15. the first gen is different. there are only 8 fuses and none are for headlights that i can tell.
i believe the plug i am holding is where the headlight relay plugs in.
tom
sassafrass
Engine Size: 2.3
Postby sassafrass » Wed Nov 10, 2010 2:01 pm
there is a bifurcating fusible link on the firewall passenger side right under the hood. one is red. one is blue. the blue one protects the headlights.
now if i only had a book that told me that (that is now on the way) instead of tracing wires everywhere...
tom
sassafrass
Engine Size: 2.3
Postby 4doorciv » Wed Nov 10, 2010 2:36 pm
So you found the problem? Good for you. So what about the connector? Test clip maybe?
-Ryan-
4doorciv
Engine Size: 4g63
Postby camoit » Thu Nov 11, 2010 5:47 pm
Try looking in here.. http://mightyram50.com/phpBB3/viewtopic.php?f=49&t=1184 It's first gen and should cover what you are looking for.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Return to Lighting
Users browsing this forum: No registered users and 12 guests
