wireing on an 83 powerram 50
Postby 83powerram50dan » Tue Dec 22, 2009 12:18 pm
would any one happen to have the wiring diagram or something i could use cause i bought my truck and the wiring is all messed up in it as soon as i turn the key the battery is dead already after charging it.
83powerram50dan
Engine Size: 2.6
Re: wireing on an 83 powerram 50
Postby mikewarme » Wed Dec 23, 2009 6:24 am
Do you have a fax? Its a fold out sheet. Ill copy it and fax it or I could try to scan it.
Start by removing any auxillary wiring that looks mickey mouse. (Wiring not done at factory. It should all be in the wrapped loom. Any wires not part of loom could be your trouble. Also maybe your battery is just no good. Can you take a photo of the wiring in the engine bay?
mikewarme
Engine Size: 2.3
Postby 83powerram50dan » Wed Dec 23, 2009 11:13 am
well i cant fax but the main positive wire goes straight to the starter but doesn't run anything in the truck who ever had it before me put two on the battery ik one if for the memory on cd player and the other powers everything in the truck and ill try get a pic of it if i can get camera to work right
83powerram50dan
Engine Size: 2.6
Return to Charging & Starting.
Users browsing this forum: No registered users and 21 guests
