no injector pulse or coil pulse
Re: no injector pulse or coil pulse
Postby joey_crandall » Fri Dec 31, 2010 7:29 am
idk yet i was gonna pull the other dizzy tomorrow and check it out.
always gift wrap your package.
joey_crandall
Engine Size: SQ
Postby camoit » Thu Jan 06, 2011 10:47 pm
Talk to us Joey. Have you had any sucess yet?
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby 4doorciv » Fri Jan 07, 2011 6:10 pm
I wonder if tis the ecu......
-Ryan-
4doorciv
Engine Size: 4g63
Postby joey_crandall » Tue Jan 11, 2011 12:22 am
i took the dizzy out and it looked fine and to be in the same condition as the one from the truck this is the one from the wrecker. so now im gonna take my ecu back to the shop that rebuilt it and have them check it out cause its still under warranty.
joey_crandall
Engine Size: SQ
Postby joey_crandall » Sun Feb 20, 2011 2:49 pm
so i got it back and they replaced the main board in the ecu but its still has no spark. should i look into the coil now?
joey_crandall
Engine Size: SQ
Postby joey_crandall » Fri Mar 04, 2011 2:06 pm
also the fuel pump doesnt turn on for a when i click the key to on?
joey_crandall
Engine Size: SQ
Postby DroppedMitsu » Sat Mar 05, 2011 12:34 pm
Could be your main relay. Square gold relay under pass kick panel. Ifthat is going badcould cause some of the problems you're seeing
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby joey_crandall » Sat Mar 05, 2011 6:35 pm
i forgot to geet that today damn it. but my brother said it seems to be working properly. one of the tabs click down when you turn the key to on and the other one clicks down when you turn it over. is one from a starion the same
joey_crandall
Engine Size: SQ
Previous
Return to Charging & Starting.
