mightyram50.net • View topic - no injector pulse or coil pulse
Postby joey_crandall » Sat Sep 18, 2010 10:28 am
so i bought a 1990 3.0 mighty max and the guy said it had a bad ecu but me and my brother pulled the ecu cas apart and it didnt smell look burnt or have any leaky diodes things either. so my brother said with the yota 3.0 if the distributor goes out it creates this same problem. are these trucks the same or does anyone have an idea of what it might be?
always gift wrap your package.
joey_crandall
Engine Size: SQ
Re: no injector pulse or coil pulse
Postby camoit » Sat Sep 18, 2010 11:42 am
More info please.
What does it not do?
Or what is it doing?
Thanks.
I'm sure some one will chime in with some help.
Crank sensor possably? IDK I don't have one of thies trucks
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby joey_crandall » Sat Sep 18, 2010 12:26 pm
well it just turns over.and the maint. required light is on. and the check engine light comes on when you turn the key on and then it goes off.
joey_crandall
Engine Size: SQ
Postby daytonatrbo » Fri Oct 01, 2010 8:50 am
Sounds like a bad crank or cam sensor.
The cam sensors are known for going bad on early 3.0 (6g72) engines. I only know these engines from the 3000gt/stealth world tho, so I may not have the most pertinent info for you. It is common practice on those cars to unplug the cam sensor so you can crank the engine and prime the oil pump or whatever, as it disables fuel and spark.
daytonatrbo
Postby lush90 » Sat Oct 02, 2010 8:46 pm
I have a '90 3.0 as does a mechanic friend of mine. We both have had to have the ecu's rebuilt within the past year or two. The symptom is just turning over, no start. with check engine light lit. I have not heard of cam sensor issues with the truck version. Be sure the short ground wire from below the glove box is attached to one of the lower bolts securing the ecu, I've heard it won't start without this. Can you pull a code? The OBD terminal is just to the right of the fuse box, under the dash and can be read with an analog ohmeter. You'll be happy once you get it going, they are great trucks! Let me know if I can be of any help.
lush90
Engine Size: 3.0
Postby lush90 » Tue Oct 12, 2010 8:39 pm
Any updates on this problem?
lush90
Engine Size: 3.0
Postby mineitnow » Wed Oct 13, 2010 9:38 am
I had a 92 and it showed the exact same symptoms. The ECU's are famous for going bad. I had mine rebuild through a guy on ebay (from Minnesota), and I was very happy with the results.
mineitnow
Engine Size: 3.0
Postby joey_crandall » Thu Nov 11, 2010 5:51 pm
i picked up the ecu from being rebuilt. it did need it. one of the caps leaked acid and burnt part of the eprom chip. but it still gust turns over
joey_crandall
Engine Size: SQ
Postby camoit » Thu Nov 11, 2010 6:35 pm
Did you replace the cam sensor?
camoit
Admin
Admin
Engine Size: 2.6L
Postby joey_crandall » Fri Nov 12, 2010 9:37 am
no i havent. my brothers bringing hoe and osiliscope today and a meter of some sort so were gonna test a few things.
joey_crandall
Engine Size: SQ
Return to Charging & Starting.
