Page 4 of 4
Re: no injector pulse or coil pulse
Posted:
Fri Dec 31, 2010 7:29 am
by joey_crandall
idk yet i was gonna pull the other dizzy tomorrow and check it out.
Posted:
Thu Jan 06, 2011 10:47 pm
by camoit
Talk to us Joey. Have you had any sucess yet?
Posted:
Fri Jan 07, 2011 6:10 pm
by 4doorciv
I wonder if tis the ecu......
Posted:
Tue Jan 11, 2011 12:22 am
by joey_crandall
i took the dizzy out and it looked fine and to be in the same condition as the one from the truck this is the one from the wrecker. so now im gonna take my ecu back to the shop that rebuilt it and have them check it out cause its still under warranty.
Posted:
Sun Feb 20, 2011 2:49 pm
by joey_crandall
so i got it back and they replaced the main board in the ecu but its still has no spark. should i look into the coil now?
Posted:
Fri Mar 04, 2011 2:06 pm
by joey_crandall
also the fuel pump doesnt turn on for a when i click the key to on?
Posted:
Sat Mar 05, 2011 12:34 pm
by DroppedMitsu
Could be your main relay. Square gold relay under pass kick panel. Ifthat is going badcould cause some of the problems you're seeing
Posted:
Sat Mar 05, 2011 6:35 pm
by joey_crandall
i forgot to geet that today damn it. but my brother said it seems to be working properly. one of the tabs click down when you turn the key to on and the other one clicks down when you turn it over. is one from a starion the same
