Having trouble starting my truck
Postby m0ta » Wed Jan 12, 2011 9:07 pm
Hey guys i just started having this problem where my key doesn't want to work and i have to sit there n keep messin wit it till it turns on.. any ideas? :|
m0ta
Engine Size: 2.0
Re: Having trouble starting my truck
Postby pennyman1 » Thu Jan 13, 2011 6:13 pm
Auto or manual? If auto, check your neutral safety switch; if manual, could be the ignition switch on the column, corroded wiring on the starter or battery cables, or a failing starter.
pennyman1
Postby m0ta » Sun Jan 16, 2011 8:04 am
Its a manual bro the problem seem to go away but ill check those things out thanks!!
m0ta
Engine Size: 2.0
Postby pennyman1 » Sun Jan 16, 2011 8:28 am
There is also a starter relay near the fuse block that can cause that problem, although I have never had to replace one on my 1980.
pennyman1
Postby DroppedMitsu » Sun Jan 16, 2011 10:21 am
Is everything else turning on when oyou turn the key, like interior lights and gauges powering up? If so then sounds like starter or solenoid or relay for starter, if not then most likely the ign switch
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Return to Charging & Starting.
