mightyram50.net • View topic - truck just wont start
Postby istunt » Tue Jan 25, 2011 6:50 am
Ive looked over everything i can think of but it just wont start, i have a 88 mighty max 2.6l. Like it will try to start if i pump gas with the pedal but it wont crank by its self. As soon as i let go of the pedal and stop pumping it just turns over but wont crank. Could it be the fuel pump? Is there a fuse located for it some where? Help would be appriciated..thanks.
istunt
Re: truck just wont start
Postby pennyman1 » Tue Jan 25, 2011 5:56 pm
Its a manual pump right next to the carb. Check to see that the fuel filter isn't plugged; its located in front of the rear wheel on the drivers side by the tank.
Postby istunt » Tue Jan 25, 2011 6:02 pm
Thanks thats exactly what it was. starts up fine now.
istunt
Return to Charging & Starting.
