mightyram50.net • View topic - NEWBIE
NEWBIE
A place to introduce yourself and get aquainted with the other members.
Come on in, we don't bite!
Forum rules
NEWBIE
Postby mighty max mafia » Tue Mar 15, 2011 8:54 am
Hey fellas im new and i got Q's out the butt. ive got a 1990 mm 2.4l its droped 3'' its got 17'' catty rims on it and is all stock other then that i wonna make it go faster and need pointers on how to do that i wonna make it a 4g63 turbo truck but im low onn the cash part so any help will be greatly thanked..... yea im from north caralina.
mighty max mafia
Engine Size: 2.4L
Re: NEWBIE
Postby camoit » Tue Mar 15, 2011 10:27 am
Welcome to the site.
We have some resident turbo guys here. One is a record holder for Boniville Salt Flats. He has one fast Max. Some where aroung 150MPH or more. I'm not sure how fast he has gone but I would bet that LSRMike will look in.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Re: NEWBIE
Postby mighty max mafia » Tue Mar 15, 2011 11:04 am
COOL sounds good thanks for the welcome glad to have found ya'll
mighty max mafia
Engine Size: 2.4L
Re: NEWBIE
Postby 4doorciv » Tue Mar 15, 2011 5:03 pm
Welcome to the board. Glad we have another potential turbo truck member. All I can say is the 4g63 swap costed me about 1800 in parts and misc crap to get it to run. Not counting gauges and the freebies I already had. Oh, and and I had to buy more parts to replace the parts that broke, like a fried ecu, coil pack, ptm module, and others. If you are on a budget I would suggest you buy a cheap running car that was in an accident to swap parts over. Otherwise I would just do the basics like webber carb and rejet it to your liking, and ignition upgrades. Somewhere small till your ready for a money pit of at least the cost of a donor car.
-Ryan-
4doorciv
Engine Size: 4g63
Re: NEWBIE
Postby mighty max mafia » Wed Mar 16, 2011 6:10 am
WOW thats sick man mine truck is fuel injected tho and im thankin bout puttin a electric fan on it and maybe a header and exaust and a better cam if i can find one that works with a 2.4l
mighty max mafia
Engine Size: 2.4L
Re: NEWBIE
Postby 4doorciv » Wed Mar 16, 2011 6:11 pm
The electric fan is a great idea. I would recomend a fan with low amperage draw like a flex a light that way you don't put too much of a strain on the alternator, but ofcourse that doesn't mean you can't pick up a used electric fan from theocal pick and pull scrap yard. The cam, I am not too sure if they sell any aftermarket replacements for performance. You can send in a spare to get it reground for performance with added lift and duration. Exhaust always sounds nice and you can put a k&n drop in filter. The 2.4 is a nice start for the starion or conquest turbo swap since you can use your current transmission.
-Ryan-
4doorciv
Engine Size: 4g63
Re: NEWBIE
Postby mighty max mafia » Thu Mar 17, 2011 6:07 am
Do you know where i can get a alumnum raidiator and a header for a 2.4l?
mighty max mafia
Engine Size: 2.4L
Re: NEWBIE
Postby DroppedMitsu » Thu Mar 17, 2011 9:12 am
Here's links to aluminum radiators
http://www.genesisautoparts.com/product ... 7705aa.htm
http://www.shepherdautoparts.com/autopa ... LCosKi.htm
Good luck finding a aftmarket header for your truck
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: NEWBIE
Postby mighty max mafia » Thu Mar 24, 2011 8:50 am
HEY DOES ANY OF YALL KNOW WHAT SIZE SPEAKER TO PUT IN THE DOOR AND THE WINDOW STILL WORK RITE AND HOW TO CUT THE DOOR OUT IF SO HELP PLZ
mighty max mafia
Engine Size: 2.4L
Re: NEWBIE
Postby DroppedMitsu » Thu Mar 24, 2011 9:30 am
I always ran 6 1/2" or 6 3/4 in my doors until I got my extended cab. But yea just make sure the mounting depth on the speaker isn't too deep and will interfere with the window. Under the door panels in the front bottom of the doors there is already an access hole, I just made that a lil bigger ancut a hole in my panels and mounted them up
-Josh-
DroppedMitsu
Engine Size: 4g63
Return to Newbies
