Need some help
A place to introduce yourself and get aquainted with the other members.
Come on in, we don't bite!
Forum rules
Need some help
Postby wabbit2004 » Tue Jul 07, 2009 4:39 pm
I replaced my carburator on my 89 ram 50 2.0 last year. For some reason I cant get the choke to work right on it. As long as I start it and do not hit the gas she is fine. But if I hit the gas before 4 mins then she will idle pretty high. Need to know how to adjust it. Also is easy to do a valve job on the truck???? Only have 78,000 Miles on it bought it with 56,000 miles on it last year.
wabbit2004
Re: Need some help
Postby RusTy Max » Tue Jul 07, 2009 5:22 pm
It is not possible to do a valve job "on the truck" because the valves face the cylinders. So the head would have to come off to remove them. NOW with that said. IF you wanted to change out the springs and retainers 'on the truck' it is a pain in the ass BUT possible. If your changing out the valves and lapping them prior to install you'd have to remove the head. I have no clue how to help you with the carb problem!
RusTy Max
Engine Size: 2.4L
Re: Need some help
Postby Ramit » Tue Jul 07, 2009 7:26 pm
Need more info about the carb.What brand is it? Mikuni?,Weber? Also what type of choke?electric?, water/coolant?,manual?
Ramit
Donator
Donator
Re: Need some help
Postby wabbit2004 » Wed Jul 08, 2009 3:22 am
Its a Mikuni Electric Choke Water/coolant
wabbit2004
Return to Newbies
