mightyram50.net • View topic - got valve timing right and swapped carb to a non fbc solex
Re: got valve timing right and swapped carb to a non fbc sol
Postby 86powerram50 » Sun Sep 26, 2010 7:10 pm
ive tried pourin gas down the carb but its not helpin
86powerram50
Postby 86powerram50 » Mon Sep 27, 2010 2:26 pm
i asked a good mechanic friend of mine and he seems to think it has a intake manifold leak
86powerram50
Postby 86powerram50 » Mon Sep 27, 2010 7:03 pm
figured it out i have a couple either burnt or bent valves
86powerram50
Postby dmr8x2 » Mon Sep 27, 2010 8:03 pm
i am guessing you have a 2.6L
i take it you just did a compression test
these moters do not have 0 clearance heads
meaning pistons don't bend valves
are you sure Dissy is set to TDS on compresion stroke
and if you still have jet valvs that none are stuck open
dmr8x2
Engine Size: 2.4
Postby 86powerram50 » Tue Sep 28, 2010 8:47 am
the distributor is not a problem but it barely has any compression even though the rings are brand new. and it has the jet valve eliminator kit. im stumped now on this truck
86powerram50
Postby 86powerram50 » Tue Sep 28, 2010 8:53 am
i just cant get it to start at all and i have no clue why it has spark, fuel ,compression but the number one plug is the only one that fouls out
86powerram50
Postby 86powerram50 » Tue Sep 28, 2010 2:46 pm
i have 3 bent intake valves
86powerram50
Postby laidoutmits » Fri Oct 15, 2010 2:48 pm
so now u figured it out, did those valves fix it?
laidoutmits
Postby 86powerram50 » Mon Oct 18, 2010 6:45 pm
yep its runnin and i have a new weber 34dgev carb on it
86powerram50
Previous
Return to General Questions.
