mightyram50.net • View topic - 88 2.0L Idle Problem
Re: 88 2.0L Idle Problem
Postby GotToGo » Wed Jan 05, 2011 3:08 pm
Here it is!
GotToGo
Engine Size: 2.0L
Postby GotToGo » Wed Jan 05, 2011 3:10 pm
Let's try this again.
Here's the picture.
GotToGo
Engine Size: 2.0L
Postby GotToGo » Wed Jan 05, 2011 3:11 pm
Ok then. There's 3 in case you missed the first 2. :)
GotToGo
Engine Size: 2.0L
Postby 4doorciv » Wed Jan 05, 2011 6:04 pm
I don't believe there is a valve in the red circle. That is where the egr valve gets the exhaust gases from the exhaust manifold. The egr valve is at the other end of that tube though. And that is vacuum controlled.
-Ryan-
4doorciv
Engine Size: 4g63
Postby GotToGo » Mon Jan 10, 2011 4:51 pm
I'm going to need some clarification here as I don't think this feeds the EGR.
The other red circle is what's at the end of that tube. And that vacuum controlled valve feeds the exhaust directly to the side of the air cleaner.
As far as I know, the EGR is on the intake manifold. But of course, I could be wrong.
GotToGo
Engine Size: 2.0L
Postby 4doorciv » Mon Jan 10, 2011 5:01 pm
The top circle is the egr vale, and the tube feeds from the exhaust manifold to the egr, then to the air cleaner with a vacuum signal.
-Ryan-
4doorciv
Engine Size: 4g63
Postby DroppedMitsu » Mon Jan 10, 2011 6:51 pm
That top circle is not the egr valve, the egr valve is on the front side of the intake manifold
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby GotToGo » Tue Jan 11, 2011 12:43 pm
I would have to agree with Dropped.
So what is this mechanism?
GotToGo
Engine Size: 2.0L
Postby pennyman1 » Tue Jan 11, 2011 4:29 pm
It is a reed valve, used in place of an air pump to inject air into the cat to dilute the exhaust gases. The valve only opens when a cylinder fires and spent gases are pushed out the exhaust manifold. If the valve is bad(stays open) it will cause a huge exhaust leak and the motor will run like crap. If you don't have smog to deal with, plug the hole in the exhaust manifold where the pipe enters. If you could find a new one, expect to pay upwards of $300 for one. Its really not necessary if the truck is tuned up for normal use.
Postby 4doorciv » Tue Jan 11, 2011 9:09 pm
Really? Hmmmm. I stand corrected. Sorry about the bad info.
-Ryan-
4doorciv
Engine Size: 4g63
PreviousNext
Return to General Questions.
