[phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4505: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4507: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4508: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4509: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) mightyram50.net • View topic - i need head
A site for Mitsubishi Mighty Max and Dodge Ram 50 Enthusiasts.
I got mine from Clearwater. They were nice to deal with on the phone. It's cast with no jet valves and comes complete with everything except the valve cover. http://www.cylinder-heads.com/index.cfm
Marnal are supposed to be way better, but I'm happy with mine. It's got 4k+ miles on it and no problems. I took the money saved compared to buying a Marnal and put ARP studs and a Weber carb while I had it apart.
