? about a 4g63 rebuild
Postby beachrat92 » Sat Jul 31, 2010 8:13 pm
hey guys
i have a 88 mighty max with a 2.0L in it.it leaks oil like no other, i have to change the spark plugs about every 1500 miles cuz they foul out with oil and the more i work on it the more i relize it would be ezer to just pull it and rebuild it.What i want to ask is about how much will it cost to rebuild it and dose anyone recomend someone who sells a full rebuild kit. thanks
- Dan
beachrat92
Re: ? about a 4g63 rebuild
Postby camoit » Sun Aug 01, 2010 3:08 pm
I have a brand new short block sitting here cheep to you. ATK rebuilt. Just swap out your head and drop in some new head studs and your flying.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby 4doorciv » Sun Aug 01, 2010 9:52 pm
A lot of confusion goes on with these motors. Lol. Oh well, Im happy with my 4g63, still got my g63b, that'll be rebuilt for fuel injected turbo soon.
OP, does the engine leak oil outside as well as inside the block? You say oil leak then oil fouled spark plugs.
-Ryan-
4doorciv
Engine Size: 4g63
Postby beachrat92 » Mon Aug 02, 2010 10:43 am
ya it leaks out of the front main seal, the oil pan, out of the back of the head and my cam seal leak a little also.i also have low compression in my #3 cylinder. i go through about a quart of oil every 800 miles. the truck runs fine as long as i put oil in it and change the plugs out and i only use it to get to school work and the beach. i am not rebuilding it right away i just want to get some info on it before i do.
- Dan
beachrat92
Postby camoit » Mon Aug 02, 2010 3:01 pm
MaxD50 wrote:
camoit wrote:I have a brand new short block sitting here cheep to you. ATK rebuilt. Just swap out your head and drop in some new head studs and your flying.
He has a G63b camoit,
Totally different engine than yours
4G63, G63B, With a grinder and a stamp kit I can make it say I love you. At least I got the 2.0 L size right. Thats worth somthing.....
camoit
Admin
Admin
Engine Size: 2.6L
Postby 4doorciv » Mon Aug 02, 2010 3:09 pm
I don't know about a full rebuild kit but maybe you can try napa or something. Some parts I'd rather go to the dealership for though. Sounds like someone may have used a bottle or so of oil stop leak since it's that bad but that's just opinion. I can be wrong that's why. Do you have any background rebuilding engines yourself? You looking to rebuild yourself? Looking for performance gains or looking to just get back on the road at oem performance? Machine shops are costly and you won't know personally if some things are changed, all you can do is look at the reciept and take their word for it. To each his own.
-Ryan-
4doorciv
Engine Size: 4g63
Return to General Questions.
