got valve timing right and swapped carb to a non fbc solex
Postby 86powerram50 » Wed Sep 22, 2010 6:26 pm
i fixed the valve timing but idk where to start played with the igniton timing a bunch but nver could get it to run smooth dont know where to start. ignition timing carb or something else??????????? need help!
86powerram50
Re: got valve timing right and swapped carb to a non fbc sol
Postby camoit » Thu Sep 23, 2010 1:23 am
Please get us more info.
What did you do first?
What have you done?
How bad is it?
What was it doing to start with?
We need the hole story. The more the better. If you can include pictures.
Thanks
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby 86powerram50 » Sat Sep 25, 2010 9:17 am
replaced timing chain, ignition coil and pick up coil. i swapped an older non fbc carb on the truck. whenever you crank it over it just spits and spudders but now it wont even run. ignition timing, valve timing, and firing order are correct but still nothin. im thinkin it may not be getting enough gas but i dont know what to adjust on this older carb
86powerram50
Postby TotallyBalistic » Sat Sep 25, 2010 9:22 am
you got the manual fuel pump on the side of the head by the carb or what
595
TotallyBalistic
Good Times
Good Times
Postby 86powerram50 » Sat Sep 25, 2010 9:23 am
yes i do and its brand new its working fine its just not spitting enough gas outta the jets or somethin
86powerram50
Postby camoit » Sat Sep 25, 2010 12:40 pm
TaKE THe TOP OFF the carb and sii if the jets are pluged with crap.
camoit
Admin
Admin
Engine Size: 2.6L
Postby 86powerram50 » Sat Sep 25, 2010 5:32 pm
float level was way too high and the intake was full of gas so im pretty sure thats it
86powerram50
Postby camoit » Sun Sep 26, 2010 12:33 pm
That might have somthing to do with it... Take pictures and show everyone what you find. Ane we want a FULL report on it just as soon as you can.. It will help out the next poor guy with the same thing. I think this is like the third one. The more detail the better. People like stories and pictures.
camoit
Admin
Admin
Engine Size: 2.6L
Postby 86powerram50 » Sun Sep 26, 2010 6:21 pm
i will take photos tomorrow. i got the float level right but its still acting like its not firing, i checked spark and its blue but it doesnt look like its a big enough spark. the number 1 plug is the only one fouling out. i honestly dont have a clue as to whats wrong. everything seems to be as it should, valve timing is right and the lash is within specs, ignition timing is right and its getting fuel. i installed new chain and tensioner, coil, ignition module, plugs and wires just to rule out those things.
86powerram50
Postby laidoutmits » Sun Sep 26, 2010 6:44 pm
if u think its not gettin enough gas try pouring a splash in the carb and see if it starts that will answer the gas question.
laidoutmits
Return to General Questions.
Users browsing this forum: No registered users and 8 guests
