mightyram50.net • View topic - Intake leaking coolant
Postby Bigbearzuke » Thu Feb 03, 2011 9:09 am
I was wondering if this is a regular occurrence. I have a '92 D 4g64 and replaced the motor in it because it was using coolant at an alarming rate. About a month after I put the new to me motor in, I split the rad causing what I thought was a head gasket to blow. Walked away from the truck for a year and finally decided to fix the head gasket 'cause I missed driving her. Replaced the gasket, new timing belts, tensioners (previous owner of the motor butchered the front end replacing the water pump) etc. Fired her up and she's still blowing white as bad as before. I haven't done a comp test but I suspect the Intake gasket again.no physical signs of cracks in the head. It looks like the gasket is quite thin at the water passage and the previous motor "sucked" the gasket into the #3 intake. This is the same cyl the new motor was wet. I was wondering if anyone else has had this experience?
Bigbearzuke
Engine Size: 2.4l
Re: Intake leaking coolant
Postby 4doorciv » Fri Feb 04, 2011 9:27 am
You said you bought a new engine. How much of the old engine was used? I know more about the 4g64 in an eclipse then I do the mighty max. I know on the eclipse, it has a oil cooler on the oil filter housing that has engine coolant flowing through it. I would start with the basic compression test, then move to a cylinder leakdown test. I don't know how much pressurizing the radiator would do since the leak is internal. Are you using felpro gaskets?
-Ryan-
4doorciv
Engine Size: 4g63
Postby Bigbearzuke » Sat Feb 05, 2011 4:28 pm
Ok so I finally was able to do a comp test and it's "ok". Cyl's 1-4 118, 108, 110, 100. I'm leaning towards the intake gasket. No leakdown test yet. The motor was a straight swap from the donar truck into mine. Nothing was touched on it. Sold my DSM back in '02 lol. I think I'm gonna take it for a burn down the gravel roads and see if it'll clear. If that doesn't work I'm pulling the intake and see. It'll give me an excuse to powder coat it lol
Bigbearzuke
Engine Size: 2.4l
Postby camoit » Sat Feb 05, 2011 10:35 pm
Ya it's in the intake system or that warm water crap for the carb.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby CheapBastard » Sat Feb 05, 2011 11:06 pm
camoit wrote:Ya it's in the intake system or that warm water crap for the carb.
dont have a carb, you betta stick wit your 4.3 and leave da mitsu's to da professinals
CheapBastard
banned
banned
Postby pennyman1 » Sun Feb 06, 2011 1:13 pm
No carb, but it does have a heated plenum at the bottom of the manifold for emissions. You need a lot more posts before you can harass people on here ;) :naughty: :shhh:
Postby LSR Mike » Thu Mar 17, 2011 12:59 pm
Actually it's the base of the TPS where the coolant passes thru. :D you can see the spigots here.
LSR Mike
#847 F/BMMP
SCTA-BNI/ECTA
LSR Mike
Engine Size: 2.4L
Postby 4doorciv » Thu Mar 17, 2011 7:54 pm
Bypassing thoughs is doable but may have cold start idling issues. Thanks mike for the pictures.
-Ryan-
4doorciv
Engine Size: 4g63
Return to General Questions.
