starting problem
starting problem
Postby 83powerram50dan » Sun Mar 27, 2011 5:19 pm
i have yet figure out what is causing this battery acts like its dead but the charger is showing to be charged an i have had the battery tested but the motor will barley turn over but when i take the spark plugs out it turns over just fine with out problem all my valves are opening i have changed an put new battery cables on it an still not turning over good enough. does any one know what would cause this?
83powerram50dan
Re: starting problem
Postby 4doorciv » Sun Mar 27, 2011 10:55 pm
You might have jumped timing. Have you checked compression? I would start with that, and see from there. Since your battery is fine and motor spins freely without resistance.
-Ryan-
4doorciv
Engine Size: 4g63
Postby 83powerram50dan » Mon Mar 28, 2011 8:28 am
well i just put the motor back in the truck an i jus re done the timing on both the cam an the oil chain i put bothe of them where the boot told me but i havent checked the other thang yet is it possible that i have to much compression
83powerram50dan
Postby 4doorciv » Mon Mar 28, 2011 1:38 pm
Too much compression might be a valve timing issue. I can't think of any thing else on the top of my head. I'm sorry but I would say you should check the marks on all the gears again.
-Ryan-
4doorciv
Engine Size: 4g63
Return to General Questions.
Users browsing this forum: No registered users and 12 guests
