mightyram50.net • View topic - How legit is this? Or 100% scam?
Re: How legit is this? Or 100% scam?
Postby crvtec90 » Sun Dec 26, 2010 7:58 am
camoit wrote:K&N filter won't hurt. On my truck if I treat it with the oil they they come with it would run rich. So I just leave it dry. The topper you are asking about is that a camper shell? The lighter a car the less power it takes to make it go down the road. Just pull it off and drive it for a week and check your milage. I would drive around with the tail gate down on mine. I don't realy know if that did help or not. My truck had a shell for years then once I pulled it off I never went back. It was just eayser to load with out it. In the "manuals" area there is a first gen factory manual that gives you a flow chart to go down with fuel millage problems. Take a look and see if there is anything there that might help you. http://mightyram50.com/phpBB3/manuals-and-source-info-f49.html
K & N Filters can burn up Mass Air Flow sensors if they are over oiled. If too much oil is used on the filter it will be sucked in by the incoming air charge and affect the sensors ability to read properly.
Drive it like u stole it
crvtec90
Previous
Return to General High Performance Questions.
