power steering
Stock Trucks.
power steering
Postby 79stud50 » Sat May 22, 2010 3:04 pm
Have a 79 dodge d50 sport without power steereing , is it possisble to installl power steering for a 1st gen 4x4 d50, if so what mods and how hard would it be to doto do? Have a chance to get 1st gen 4x4[not road worthy] for cheap to strip for parts.
79stud50
banned
banned
Engine Size: 2.6L
What year vehicle do you own?: 1979
Re: power steering
Postby pennyman1 » Sat May 22, 2010 6:36 pm
won't work - the steering box is on the outside of the frame for a 4x4 and on the inside for the 2wd. I do believe that a starquest (starion/conquest) steering box can be installed rather easily; they are also easier to find. How did you find a d-50 sport w/o power steering? I thought all sports had p/s standard; I've had several 79/80 sports and all had p/s. I may have one to sell once I see what it takes to install p/s on my 86 ram 50; its a 2.0 and I need a p/s pump bracket.
Re: power steering
Postby 83L200 » Sat Jun 05, 2010 12:59 pm
my 83 dosnt have power steering
83L200
Engine Size: 4G63
Re: power steering
Postby DavetheDude » Tue Jun 15, 2010 7:12 am
While we are on the subject, does anyone know what it takes to convert a non power steering truck to power steering. Does the whole column have to come out or can you bolt on the new unit on the end. This is 2nd generation and I want to convert a 2wd non power steering to power steering from a 4wd donor truck.
DavetheDude
Re: power steering
Postby pennyman1 » Tue Jun 15, 2010 4:21 pm
As we have said before, you need a p/s box from the 2wd for a 2wd or use a conquest box. the 4wd mounts outside the frame, the 2wd inside. Unfortunately, most 2wds did not have p/s, most 4wds did. the pump and block mounts are the same though. I bet I could make a fortune on the 2 0r 3 spare p/s boxes I got laying around... not really. I have the boxes, but the conditions are unknown at this time.
Re: power steering
Postby DavetheDude » Tue Jun 15, 2010 6:15 pm
But if I found one would it be just a matter of bolting it on?
DavetheDude
Re: power steering
Postby pennyman1 » Fri Jun 18, 2010 9:46 am
If you find one, you need the rag joint to match the p/s box; its different than the manual column. Besides that and maybe the pitman arm, it bolts in.
Return to Stock Front & Rear Supension, Steering.
