mightyram50.net • View topic - Lowering shall begin!
Postby m0ta » Sat Jan 08, 2011 10:50 pm
Hey guys i passed my emissions today! So i got a question about lowering the mitsu in the front.. How many coils should i cut to get a 3''-4'' drop?any pics? n is it true if i get spindles i have to run a bigger wheel? thanks
m0ta
Re: Lowering shall begin!
Postby camoit » Sat Jan 08, 2011 11:09 pm
I would use drop spindles. Cutting springs is asking for trouble later on.
Here is my BUILD THREAD.
http://www.onsiteconcrete.net
camoit
Admin
Admin
Engine Size: 2.6L
Postby m0ta » Sat Jan 08, 2011 11:13 pm
n what kind of blocks should i get? 2 degree taper?
m0ta
Postby camoit » Sat Jan 08, 2011 11:32 pm
That would depend on how low you go. the amount of deflection from stock would be min. Look in the rear end section under stock engine and power train, for a post about pinion angles. It helps you to under stand what to look for.
camoit
Admin
Admin
Engine Size: 2.6L
Postby wrngwae » Sun Jan 09, 2011 5:42 am
i bet this one will make the sawzall section. but some use s10 drop spindles and 4" lowering blocks. if you cut the springs it will ride like ass too.
or Chinese parts!!!!
764  768
wrngwae
Super Mod
Super Mod
Engine Size: 2.3
Postby m0ta » Sun Jan 09, 2011 8:19 am
if i get spindles do i need to get a bigger wheel? n im planning on doing a 4in block in the back
m0ta
Postby pennyman1 » Sun Jan 09, 2011 9:03 am
With 14" you might - it will depend on the backspace of the wheel. Be sure to cut the stop on the lower control arm in half to get more travel on compression. To compensate for the 4 inch blocks, raise the center carrier bearing up by using either large washers or making a spacer from 1/4" plate for each side.
Postby m0ta » Sun Jan 09, 2011 9:51 am
i will be using a 14in stock wheel
m0ta
Postby 4doorciv » Sun Jan 09, 2011 10:32 am
Well, if you wanna make it to the sawzall section, one complete coil would drop the truck 2inches. So one and a half coils would get you the 3 inches. Also removing the middle leaf would get you 2 inches, and get angled blocks if you don't wanna get spacers or washers to change the pinion angle. Drop spindles if I remember correctly were a 17 inch rim minimum cause of the lower ball joint touching the rim but don't quote me on that. You can also find lowering springs if you search google. As for air shocks, Nissan hardbody rear shocks fit our trucks. Don't remember the fronts. Been too long since the old mightyd50 site for me to remember.
-Ryan-
4doorciv
Engine Size: 4g63
Postby pennyman1 » Sun Jan 09, 2011 1:22 pm
Lowering cois are made for the drop with stiffer rates to comp for the drop with a good ride. Cutting stock coils screw up the rate and turn the ride to shit. If you are wanting to stay with the stock 14" wheels, use the drop coils and shorter shocks
Return to Genral Questions.
