mightyram50.net • View topic - Toyota 5 lug swap
Toyota 5 lug swap
Toyota 5 lug swap
Postby tsiturbomightymax » Tue Mar 22, 2011 10:59 am
Who here has done this and does anybody have a writeup? I am more or less looking for what year toyota and just front how to.
tsiturbomightymax
Engine Size: 2.4
Re: Toyota 5 lug swap
Postby DroppedMitsu » Tue Mar 22, 2011 12:10 pm
I am almost in the process, waiting for my rear axles to come back from getting redrilled then its all going on.
For the front:
You want 89-up toyota pickup hubs
Same year pickup rotors or 95-99 tacoma rotors(what im using, supposably require less shimming of brake caliper)
Use new toyota bearings and seal and mitsu 4x4 studs.
Rear:
pull rear axles out and get redrilled
Or Toyota rear end and have driveshaft modifed to mate to toyo rear end.
If I had to do it again id probably go toyo rear end it would be quicker, cheaper, and probably a little easier.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Return to Genral Questions.
