Report this postReply with quoteRe: 2 LINK
by Johnboy72 » Wed Sep 09, 2009 7:49 pm
You can probably use the heim joints/bushings on the end of you 2 link bars. We've used 2x2 in the past. Long u bolts on the axle side. 2 link length will depend on your driveshaft. But you shouldn't need a ton of lift back there man. As far as a locator bar, I'd use a track bar. Basically it will be tabbed and bolted from the axle end of one bar up to the joint end of the other bar. I don't have any pics of my Rangers old set up or my brother "El Cheapo" S10
