I want to start a post for the toyota 2WD front 5lug hub into the Might max truck.
I know it is doable in the second gen trucks but i would like more info on the first gen trucks.
Please chime in if you have detailed info.
TotallyBalistic wrote:im just wondering what the purpose in this swap is, is it the same bolt patter as the small 5 pattern on ford or chevy. whats the deal here? im just curious
TurboMax wrote:Here's some info on a 2gen 5-lug swap. The same info should apply to the 1gen.
http://mightyram50.com/phpBB3/viewtopic.php?f=21&t=267#p1515
pennyman1 wrote:An 8-3/4 mopar axle from an A body car(dart,valient, duster) will fit width wise under a d50- all that is needed is to relocate the spring perches and adapt the driveshaft. Be sure to get the large bolt pattern(5x4 1/2)
MaxD50 wrote:I have a new chrome grille, where are you located?
