coil over springs
coil over springs
Postby villacorta32 » Fri Feb 05, 2010 3:54 pm
anyone know if there are any out there for the mm or if there are any we could use on the truck?
villacorta32
Re: coil over springs
Postby LethalEthan » Fri Feb 05, 2010 4:02 pm
I could go on for days about building a coilover setup on a minitruck. But as for easiest you could go with a shock type coilover like a QA1. They make them for old hot rods that mount just the same as a normal shock absorber does. You would still have to have some sort of locating device for the rear but you could just leave the leaf springs on for that i suppose.
LethalEthan
Engine Size: 2.3L
Postby villacorta32 » Fri Feb 05, 2010 5:56 pm
im just trying to do coil overs for the front for right now, would the qa1 work for the front
villacorta32
Postby LethalEthan » Fri Feb 05, 2010 7:00 pm
your best bet would be to try and see if any of these will fit
http://qa1.thomasnet.com/viewitems/moto ... &forward=1
you can get the springs from that site also. They are a bit pricey but these are great shocks and they have adjustable ride height of course.
youll also need something like this http://qa1.thomasnet.com/item/motorspor ... &forward=1
check on these as well
http://qa1.thomasnet.com/viewitems/spor ... &forward=1
they have alot of great stuff on their site and im sure you can find what your looking for there.
LethalEthan
Engine Size: 2.3L
Postby villacorta32 » Fri Feb 05, 2010 10:27 pm
thanks E
villacorta32
Postby villacorta32 » Sat Feb 06, 2010 4:45 pm
also my tie rod bushing are shot to hell, wut should I do?
villacorta32
Postby pennyman1 » Sat Feb 06, 2010 5:20 pm
Do you mean strut rod bushings or tie rod boots?
Postby villacorta32 » Sat Feb 06, 2010 9:56 pm
strut rod my bad, I think the two rods that run kinda like this toward the front /\
villacorta32
Postby pennyman1 » Sun Feb 07, 2010 7:18 pm
Go to this site, they have all the urethane bushings including the strut rods:http://www.suspension.com/Dodge%20Dakota.html . Don't let the name fool you they ahave the d50 bushings also
Return to Genral Questions.
