So I had a few quick questions.
1) Will 10.5" extended for 2500lbs bags and 12" extended for 2600lbs bags be too much of a lift for a mighty max?
2) Will 6.5" diamter for 2500lbs bags and 7.5" for 2600lbs bags be a good fit for a mighty max?
3) If I remove everything (bed, gas tank, crossmember, etc.), leave the leaf springs at stock height, put the wheels back on, and set the truck on level ground, could I just weld up my 4 link at that point to give me a correct pinion angle?
