mightyram50.net • View topic - Where does this part go?
Postby pdub » Thu Aug 19, 2010 4:57 pm
I'm putting my truck back together - but I found a heat shield an I can't seem to remember where it goes. :oops:
I found it laying in the engine bay close to the AC unit, but that may not mean anything at all.
Can anyone tell me where this goes?
Thanks!
pdub
pdub
Engine Size: 2.3L
Re: Where does this part go?
Postby pdub » Thu Aug 19, 2010 11:17 pm
Thanks! That's great!
pdub
Engine Size: 2.3L
Return to Genral Questions
