mightyram50.net • View topic - Wheel adapters
Wheel adapters
Forum rules
Wheel adapters
Postby 87mightymax » Mon Sep 13, 2010 6:10 pm
whats the best way to go from the Mighty max 6lug to like a 5 lug camaro wheel, i have a few sets of camaro wheels laying around that i would love to put on my truck but not sure how to go about putting them on can anyone help.
87mightymax
Re: Wheel adapters
Postby dmr8x2 » Mon Sep 13, 2010 9:38 pm
adapters look to be $200
might it just be cheaper to find better rims
http://cgi.ebay.com/ebaymotors/6-LUG-5- ... ccessories
dmr8x2
Engine Size: 2.4
Re: Wheel adapters
Postby 1986goldmax » Tue Dec 14, 2010 6:03 pm
swap toyota front hubs and do a toyota rear end. that will give the better bolt pattern. it will cost more but nicer in the long run
mike
1986goldmax
Re: Wheel adapters
Postby 4doorciv » Tue Dec 14, 2010 7:48 pm
Also the Toyota hubs would allow you to tuck some wheels, the rear end is a little more narrow. And I believe the front may come in a bit more also. I could be wrong about the front though. :think:
-Ryan-
4doorciv
Engine Size: 4g63
Re: Wheel adapters
Postby DroppedMitsu » Wed Dec 15, 2010 8:59 am
I would not do adapters, they will push the wheel out like an inch or two, you will never tuck anything. Best way to do it is swap to toyota hubs and rotors up front and redrill or toyota rear end in the back. There is a thread on Toyota 5lug swap if you want to look into it.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Re: Wheel adapters
Postby pennyman1 » Wed Dec 15, 2010 6:25 pm
You are all missing the point of his question - using the camaro wheels. The toyota swap won't work because it is a 5x4.5 bolt pattern, and the camaro wheels are 5x4.75. He would need to swap to s10 hubs and rear axle to make them fit, and I haven't seen anyone do that one on here yet.
Re: Wheel adapters
Postby 4doorciv » Wed Dec 15, 2010 6:34 pm
Oh. I'm sorry, completely forgot about the bolt pattern of the rims.
-Ryan-
4doorciv
Engine Size: 4g63
Re: Wheel adapters
Postby pennyman1 » Wed Dec 15, 2010 6:50 pm
You're forgiven this time. Just don't let it happen again... :D :mrgreen: :doh:
Re: Wheel adapters
Postby 4doorciv » Wed Dec 15, 2010 7:46 pm
It might. ;)
-Ryan-
4doorciv
Engine Size: 4g63
Return to Wheel & Tire
