Lincoln navi rims 18s
Forum rules
Postby andrew » Mon Jan 24, 2011 11:39 pm
Will Lincoln navigator rims fit my d50? I know I have to bore the center hub out but is the lug pattern the same? Rim info18x8 6 lug 135mm lug pattern.
andrew
Re: Lincoln navi rims 18s
Postby DroppedMitsu » Tue Jan 25, 2011 7:27 am
No, the pattern is wrong. It is too small, but ppl have had the rims redrilled to the correct pattern. I would onlyuse hem if I had that done by a machine shop
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby pennyman1 » Tue Jan 25, 2011 5:45 pm
Yes they are a smaller pattern 6 x 139.7 vs 6 x 135 for the Navi. A lot of aftermarket wheels are now coming slotted to fit both since they are so close.
Return to Wheel & Tire
