recheck your grounds
there is a flex braid on the passenger side fire wall to the exhaust manifold
your negative cable runs from the battery past to a bolt just under the battery tray and then to the engine block
your head unite must be grounded to the body , there is a screw behind the radio for this (there is NO ground wire in the harness ,there is a ground wire for the factory radio light bulb but i think it goes thru the dimmer , if used it may blow light fuses)
you can ground your amp if behind the seat to the seat mounting bolt . also make shure your amp wire is large enough at the least a 10 gauge and you have a fuse at each end of it
good luck
