engine sound through speakers?
Forum rules
Postby maxFTW » Tue Oct 20, 2009 7:17 am
sound like an exhaust leak through my speakers when i have my radio on but turns off if i have radio off.
bad ground ?
what is that?
:think:
[-]===Ram===[-]
I wouldent hit a lady but i would beat a bitch!!
-89 ram 50 2.0 2wd
-Soon to be 4g63t
maxFTW
Re: engine sound through speakers?
Postby LethalEthan » Tue Oct 20, 2009 8:49 am
Your speakers are most likely picking up noise from your alt. I think they make an inline noise filter you put in the power wire to the radio.
LethalEthan
Engine Size: 2.3L
Postby DroppedMitsu » Tue Oct 20, 2009 8:49 am
yea I would check the grounds on your stereo system
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby 4doorciv » Tue Oct 20, 2009 12:53 pm
You got an aftermarket system? Could be related. Was told if run the power wire next to the rca wires it would pick up the noise. Don't know of any truth to it but that's what I was told.
-Ryan-
4doorciv
Engine Size: 4g63
Postby TotallyBalistic » Tue Oct 20, 2009 7:08 pm
is the radio wired dirrectly to the battery
595
TotallyBalistic
Good Times
Good Times
Postby maxFTW » Tue Oct 20, 2009 8:44 pm
well its wired to an amp that powers my speakers. but the radio still turns on just no sound when i dont have it hooked up
obviously:/
[-]===Ram===[-]
-89 ram 50 2.0 2wd
-Soon to be 4g63t
maxFTW
Postby LethalEthan » Tue Oct 20, 2009 8:57 pm
if you have an amp they have a noise filter you can get at walmart that goes inline with the rca'a to the amp and cuts noise. I had to run one when I had subs in my mightymax
LethalEthan
Engine Size: 2.3L
Postby DroppedMitsu » Wed Oct 21, 2009 9:03 am
If you run an amp in your vehicle make sure to run the power wires and RCA cables on the opposite sides of the vehicle. If they are both ran on the same way to the amp this could be what is causing your engine interferance in your speakers.
-Josh-
DroppedMitsu
Engine Size: 4g63
Postby pennyman1 » Thu Oct 29, 2009 6:18 pm
Make sure your ignition wires aren't arcing; the amp will pick that up too. Also ground the amp case and radio to the battery will help also. They do make a filter that hooks up to the alternator to filter the output, but if the noise is that bad from the alternator, its got a problem.
Postby 79D50 » Fri Oct 30, 2009 7:19 am
1. Proper ground with 10 guage wire.
2. Run your power to your deck seperate from AMP power.
3. Run AMP Power directly off of the battery and tie that in to your ignition.
4. Run RCA's and Speaker Wire from deck in shielded conduit
5. Make sure you use high quality, sheilded wires, RCA's, plugs etc. (Monster Products are the best IMO for audio installs)
I've never used any filters or gadgets with any aftermarket installs. You don't need them if you install the system correctly.
79D50
Donator
Donator
Return to Audio & Electronics
