mightyram50.net • View topic - 2.6lt Engine needed
2.6lt Engine needed
Need a part? Post in here to see if someone has it.
Forum rules
All Wanted Item Are Automaticly Removed After 60 Days.
2.6lt Engine needed
Postby kstokes606 » Sun Oct 10, 2010 5:51 pm
I have a 1988 D-50 that I am trying to find an engine for it. I have been trying to get this on the road for over two years off and on. I have replaced the pistons and rings, turned the crank, new bearings, and a few other things. I just had the truck running a month ago, and it started to run bad and then quit. I have water in the oil, so I remover the head and every thing looked fine. I remembered that the bots were the same ones from the other head gasket job. I need to find one that is in running condition, or a cheap re manufactured short, or long block. If anyone has any ideas, let me know. Thanks kstokes606
kstokes606
Engine Size: 2.6l
Re: 2.6lt Engine needed
Postby TurboMax » Sun Oct 10, 2010 8:27 pm
kstokes606 wrote:... I remembered that the bots were the same ones from the other head gasket job. ...
You can't reuse the headbolts. New head bolts should be used.
TurboMax
Engine Size: 2.6T
Postby greasyglass » Sun Oct 10, 2010 10:01 pm
i have an 87 raider 2.6 with 8500 miles just put a diesel in so if you want it 500$ call ryan at 860 966 8827 im in ct
greasyglass
Engine Size: 2.3
Return to Wanted
